Exporting Hair with Dynamics?
https://forum.reallusion.com/Topic519438.aspx
Print Topic | Close Window
By bossdeff - 4 Years Ago
Hello, I was trying to export a character animation from iclone with the hair dynamics that it has. I used a hairstyle that when sent from CC3 to IC7 it had hair dynamics already set up & working, but i send it back to CC3 to export as FBX into Blender and the hair animation doesn't go with it.
I don't see an option to export Alembic from CC3. I tried using Motion Plus but that doesn't work either.
Is it not possible to export hair dynamics without 3DXchange?
By AutoDidact - 4 Years Ago
You need to use Iclone for alembic export, not CC3.
Which means i would need 3D exchange then :(, welp looks like they got me to a point to have to upgrade to iclone 8.
By Wilby - 4 Years Ago
bossdeff (7/6/2022)
Do you mean 3DXchange is still required to be able to successfully export Hair Dynamics (using Smart Hair system)? Even just using iClone 8 + Character Creator 4 combo, that still cannot be done? ...or did you upgrade to iClone 8 already and have success with exporting Hair Dynamics through that software alone?
AutoDidact (7/6/2022)You need to use Iclone for alembic export, not CC3.
Hi AutoDidact! I tried your advise and it doesn't seem to work. I used iClone 8 to Blender 3.3. Can you provide any clues or maybe the proper settings to use when exporting? In iClone 8, I exported using Alembic format (abc) and selected Ogawa file format as Blender won't accept HDF5 anymore. I have also checked Project->Softcloth->Bake Animation (enabled->played animation->disabled) before exporting. Please refer to the images below for more info.
https://forum.reallusion.com/uploads/images/8df8ea46-a96f-4902-a907-ce11.jpg
Just got it! But now, I guess I have to manually add all those textures to the model in Blender since importing Alembic file did not go through like when using Victor.Soupday's CC/iC Pipeline Tools (FBX import):crying:
3DXchange Pipeline DOES NOT seem to support exporting to Alembic (abc) file format. This means iClone 8 is REQUIRED if you wish to export hair animation? I hope this important information is clearly indicated for the Reallusion Smart Hair products.
But I noticed I have the option for exporting to .abc in iClone 7 and it's just disabled because I do not have 3DXchange Pipeline. Maybe the table above is outdated. :ermm:
https://forum.reallusion.com/uploads/images/6b140db0-e134-48e3-81ac-040e.jpg
EDIT: To those interested, iClone 7 with 3DXchange supports exporting to Alembic (abc). Importing is supported even without 3DXchange Pipeline. But I still don't know how to properly and automatically import all the textures.  Related forum thread here and more product info can be found here.
