Multi PC live link will not transfer
https://forum.reallusion.com/Topic519052.aspx
Print Topic | Close Window
By livecleo - 4 Years Ago
Hi I have followed all the steps all of the plugins are setup, the plugins and the content folders are correct.
On the same pc everything works great (but to much lag) but when I use my other PC to accept UE5 it wont work.
I have tried multiple Ip addresses like my 10.1.1.X (ipv4) and also my 12 digit public? Ip address 123.xxx.xxx.xxx.xxx with the same default port 54321 and I cannot transfer it gives that error that I have to set it up.
I am able to link but not transfer. It might be a licence issue as I only have 1 seat" so I deactivated my other PCs licence but now how do I activate it on the new pc? Its already installed via marketplace..
Is this forum dead? Is there a better place I can get help? I have spent so much money on this and theres no help.
Support is days between answering and there advice is not help.
Realy want to get this transferring between computers, cant get answers and im burning through my 10 allowed licence transfers trying to get it to work.
By StyleMarshal - 4 Years Ago
As far as I know it is not possible to transfer between different PC's , you should use migrate or fbx import , live link should work.
Thats weird I thought you can click transfer then link to animate that what reallusion had me believe...
otherwise I wouldn't be able to create blueprints and other necessary files
livecleo (7/2/2022)
When migrating you migrate all BPs you need and when importing via FBX you can let Live Link create the Actor BP for you on every PC where LL is enabled as plugin , so nothing is missing. You only can't transfer to other PCs.
How would I do that then?
I tried exporting to a hard drive and importing on my second computer. I got some errors about missing bones and a renamed tearline file.
More importantly when I apply live link option to apply blueprints to the skeletal mesh nothing will animate dispite all lights being green on livelink. Iam 100% stuck.
