Edge dissolve or opacity of 3d blocks and walls
https://forum.reallusion.com/Topic518264.aspx
Print Topic | Close Window
By sombat.khruathong - 4 Years Ago
Hi!
I would like to know if there is an effect for setting the opacity of the edages of any blocks and walls.
I would like to put two blocks and dissolve the right edge of the first one and the left edge of the second one.
By wires - 4 Years Ago
You can create and add your own opacity maps to achieve such an effect. Use the UV map as a reference and add gradients as required.
