How Do I save Prop Sets in iClone 8?
https://forum.reallusion.com/Topic517952.aspx
Print Topic | Close Window
By Vault309 - 4 Years Ago
Im trying to save a scene to be reused/loaded into another project.  I have successfully saved the landscape, sky, water and loaded them in fine.  How do I save all the props.  The conventional method of selecting all of the props and saving into the custom prop folder isnt working.  It doesnt give me a prop option when saving it.  Only project, stage, and set options.  Any help or a point towards a tutorial for this would be great.  Thanks in advance.
By Peter (RL) - 4 Years Ago
Hi...
You can load a Dummy Prop into your scene, then Attach all the other props to the Dummy prop. Now save the Dummy Prop and all the other props will be saved with it.
Note: Any prop can be a Dummy prop. Just put a check in the "Set As Dummy" box on the Modify Panel.
By Podman1000 - 4 Years Ago
Use the new 'Merge Projects' feature in iClone 8.  I true lifesaver, and highly requested.
