By wintoons - 4 Years Ago
Just wanted to ask, is there any where you can standard glass shader/material which you can add on an object in clone?
By wires - 4 Years Ago
There are a lot of free Substance glass materials available on the web that can be used. There are also a few simple ones included with iClone in Content > Media > Traditional.
Yeah I know about those, I'm actually after clear glass that you can see through like ordinary window glass.
By Terry Miller - 4 Years Ago
What I found worked well for me (as far as a window is concerned) was to use the new reflection/mirror prop, then reduce the opacity and play with the reflection strength and reflection blur. It took a bit of experimenting, but I thought added enough detail to make it believable. Good luck. Terry
