Problem importing from DAZ Studio into CC4
https://forum.reallusion.com/Topic516475.aspx
Print Topic | Close Window
By facr73 - 3 Years Ago
Hi, I have some issues with some features in CC4 and one of them is the importa a character from DAZ with the transformer. It come nicely in CC3 but not in CC4. The textures doesn't come as they should and especially the normal maps as tou can see in the images below.
Import into CC4:
Import the same fbx in CC3:
Does anybody have the same problem?
facr
By MBusch - 3 Years Ago
Please add a vote on FeedBack Tracker Issue 8508
By animagic - 3 Years Ago
Mike Kelley published a video about this:
By Peter (RL) - 3 Years Ago
Please can you let us know if the problem is the same after the Character Creator 4.01 update. Thanks.
Hi Peter.
I can only test it on saturday as i'm absent. But I let you know then.
By ccsmith1 - 3 Years Ago
CC4.01 is not working when importing from DAZ I get the same result which is shown in the above video. I tried on a couple times today.
By Genursus - 3 Years Ago
Same here. I use Daz a lot. Still happens with CC4.01. I attached images. The one with the accessory belt on the floor was brought in using the Transformer. The other was brought in using Import. It would also save a lot of time if Bump maps were brought in. Is there a way to do that with CC4? I always have to add Bump maps manually. Also, if you look to the left of the sliding bar on the animation player, there seems to be a small box of colored dots. Is that just a visual glitch? I just seemed to notice it in the last day or so. I attached an enlarged picture of it.https://forum.reallusion.com/uploads/images/402e4a55-b7f6-4dea-a8ef-795e.pnghttps://forum.reallusion.com/uploads/images/2c480261-160e-423d-8ccb-f8a4.pnghttps://forum.reallusion.com/uploads/images/333f4fad-4ee5-40f0-9350-e970.jpg
Hi @Peter.
As stated in previous comments it continues to have issues.
There is also another entry in the FeedbackTracker:
https://www.reallusion.com/FeedBackTracker/Issue/Lots-of-issues-importing-Genesis-8-figures-from-DAZ-using-Transformer
Thank you checking using 4.01. We are looking into this issue and hope to have news of a fix soon.
