Widget loads but video doesn't play
https://forum.reallusion.com/Topic51588.aspx
Print Topic | Close Window
By Bard777 - 16 Years Ago
I am self hosting.  I have create a video in popVideo and exported a widget.  I then used WidgetCast Pro to export the page code and _SourceFile directory.  I added the code to my page, but when it loads the widget loads the video does not play.  I get the little gears and it goes from 0% to 100%, then nothing.
Any help would be great!
Here is the URL in case anyone wants to see what I am talking about:
http://www.visionaxis.com/
It works fine when I preview it, so it must be something with the HTML/CSS.
By Peter (RL) - 16 Years Ago
Hi,
Without seeing the project and code it is difficult to say precisely what is the cause.
I would advise you contact Reallusion Technical Support using the link below. They will be able to help you with advice and some things to try which will help you resolve this issue.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
Thanks.
