iclone 8 and 3dxchange functionality.
https://forum.reallusion.com/Topic514769.aspx
Print Topic | Close Window
By Warped Reality VFX - 4 Years Ago
Quick question before I purchase iClone 8 when I started with Iclone 5 we needed 3dxchange to import props in, so do I need CC4 to import daz3d props in, or is Iclone 8 capable of doing this function alone?
Thank you so much.
By Kelleytoons - 4 Years Ago
You can drag and drop things like accessories into iClone 8 without the need of any other programs.
CC4 is for avatars - now, you can also do the same thing in it for accessories, but it's not needed if you aren't using avatars.
Thank you for your reply, Kellytoons.
By tcheng00 - 4 Years Ago
I made a custom character/avatar in Blender and rigged it.  In iClone7, I can just import the character using 3D Exchange.  In this case, it looks like, I will need CC4 to import my character into iClone 8.  Would this be correct?  Thanks.
By Peter (RL) - 4 Years Ago
tcheng00 (6/13/2022)
For importing rigged characters you would use CC4 rather than iClone 8. However, you can still use 3DXchange 7 for this process if you prefer. Characters converted using 3DXchange can still be used in iClone 8.
