Create CC3 Custom Content Link Question.
https://forum.reallusion.com/Topic514372.aspx
Print Topic | Close Window
By jbiziou - 4 Years Ago
Hello everyone,
  I am upgrading from CC3 to CC4 and wanted to import all my content from CC3.
  I followed the Video to Create CC3 Custom Content Link.
  https://www.youtube.com/watch?v=jgYVOalKD0A&t=118s
 But I am presented with this,
                 *    Additional Character Creator 3 Custom folder(s) found     Please select a unified directory,   *
What is the best way to create a unified directory ?  Could someone please give me an example of what this should look like ?
I do not want to accidently create extra copies or confuse CC4 or CC3 should I need to use it,
 thank you
 ~ Jourdan ~
Windows10
By Peter (RL) - 4 Years Ago
Hi Jourdan
The Unified Directory is used when you have a custom content directory setup. If you don't have a custom content directory previously setup in CC3's Smart Gallery then you can ignore this. If you continue to watch the tutorial from the point linked below you will find this is explained further.
https://youtu.be/jgYVOalKD0A?t=224
Thank you Peter :)
  Ill watch it again, and go through the content setup again ,  much appreciated,
~ Jourdan ~
By Auroratrek - 4 Years Ago
Peter (RL) (5/17/2022)
Hi Jourdan
Hi, I have the same problem with the Unified Directory issue. I watched the video, but I'm still confused. I think my custom content from CC3 is using the default directory, I don't recall changing that. In any case, it doesn't seem like you can "ignore" the dialog box asking about the Unified Directory, since if you close it, or hit cancel, it cancels the operation. If you proceed with the operation, then it has you search for a folder. Should I be looking for the CC3 custom folder, or some other folder?
