PopcornFX Super Tools
https://forum.reallusion.com/Topic514082.aspx
Print Topic | Close Window
By Genursus - 4 Years Ago
Any way to install PopcornFX Super Tools into Iclone 8? The other Popcorn FX's show up fine, but the Super Tools bonus says 'Get it', but I have it. I even clicked the image that says 'Get it' and right clicked 'find file'. It shows that it's there installed, but I can't get rid of the 'Get it' which takes me to the website when I try to load it.
I had this problem before in Iclone 7 (which I still have and is also installed there). The solution was to install from my order history. That didn't work this time. It only re-installed to Iclone 7, not 8. I did click the 'I'd like to install to a specified version', but the link only shows version 7.93, no Iclone 8.
By ken_1171 - 4 Years Ago
I have installed it straight from the "uninstalled" list, and it's showing in my content list in IC8 with the "GET IT" as you said. So yeah, I confirm this issue is happening to me too. I own it, but the license is not working.
By miro219 - 4 Years Ago
the same for me - I bought a long time ago, in version 7 it works, at 8 screams GET IT - and it sends me to the site
By 4u2ges - 4 Years Ago
All IC8/CC4 plug-ins you are entitled for should be installed from a special page (not from the hub): https://www.reallusion.com/event/freeproduct/default.aspx?cid=292&chk=7417146ea8b2c7a62b2b454c5d99134d
Make sure you are logged in to your RL account (with which you have purchased plug-ins originally) and then run this link.
Thanks for the response. I installed it that way and I even re-installed it that way just now and it still doesn't work. It's just the Super Tools part that isn't working (which I think was a bonus). All other Popcorn FX is fine.
Genursus (5/15/2022)
I see what you mean..
Mine were also the same, I just realized that :w00t:
Here is what I did:
Right mouse click on Super Tools and Uninstall it.
https://forum.reallusion.com/uploads/images/86df3582-f1d7-4bb9-a6d8-591f.jpg
And then click again and Install. They should loose "Get it" status and be installed..
Now that worked. Thanks!
It's a bit confusing because I just didn't think to look under the 'Pack' tab. You can't 'right click uninstall' under the 'Item' tab.
Uninstalling and reinstalling from the Pack tab has worked for me too. Thank you! ^____^/
By justdentures - 4 Years Ago
Yes, I just spent 5 hours trying reinstall, uninstall, update etc.
Even downloaded from the upgrade page they gave me. I will try that link in the other post. Placed a support ticket. See what happens.
