new BVH motion files
https://forum.reallusion.com/Topic513867.aspx
Print Topic | Close Window
By General Picture Animation - 4 Years Ago
Bandai Namco has freely released 2 sets of mocap (over 400K frames in bvh) for AI/ML research.
I haven't D/L it because I don't know how useful it will be.
The download ZIP is found on the link.Bandi-Namco BVH
If you find something cool, let us know.
By 3dSphinx - 4 Years Ago
Wow!! Thanks for this will definitely check out!
By 4u2ges - 4 Years Ago
Thanks, those are great motions.
Here is a GitHub page in English to download BVH motions
I also made a 3DX Characterization Profile so that desired motions can be easily batch converted in 3DX7.
Note: The attached profile would only work in 3DXchange7. In other words, to convert motions you need to have IC7 and 3DX7 retained.
Sample:
https://forum.reallusion.com/uploads/images/d2bd4dfa-a161-4013-be98-df97.gif
By ApplebiteMedia - 4 Years Ago
Forgive my ignorance but how does one use/install these?
By tripfreak - 4 Years Ago
As 4u2ges said, you have to (batch) convert them in 3DX.
I used the first dataset from Bandai (175 bvh files) and shortened the names with the Renamer (optional):
https://forum.reallusion.com/uploads/images/4839a465-8f57-4ca1-8408-832e.jpg
Then I dragged the first motion in 3DX and converted it to a Non-Standard Character:
https://forum.reallusion.com/uploads/images/3171af3d-1b36-4c42-a9a8-9a75.jpg
Therefore, I used and loaded the Profile from 4u2ges and converted the Character:
https://forum.reallusion.com/uploads/images/8c6c73fa-185c-4b6f-b4f5-7651.jpg
Afterwards, I imported and converted all other bvh files (174):
https://forum.reallusion.com/uploads/images/dd6f1357-d459-4899-b505-c902.jpg
https://forum.reallusion.com/uploads/images/bfbea7d9-a093-48ea-8991-9e85.jpg
Then I shortened my converted clip to frame 2 and renamed it to "T_Pose" and added all clips (175) from the Motion library to the Perform Editor:
https://forum.reallusion.com/uploads/images/79502180-32a0-434d-8afd-012f.jpg
Now you only need to rename the data and export the motions (click "Export Animation" and "Export rlmotion") with or without the character ("Export Gemetry"):
https://forum.reallusion.com/uploads/images/5a704a02-9288-407e-a5e6-778b.jpg
Ready!
In iClone just choose one of your motions:
https://forum.reallusion.com/uploads/images/a888aae8-d601-472c-8476-fdd3.jpg
and start the animation:
https://forum.reallusion.com/uploads/images/4eac4385-bbcf-4b2f-91de-b47c.gif
Thanks to 4u2ges for the Profile! :)
By yepkoo - 4 Years Ago
If I'm not mistaken, these gestures are licensed under Creative Commons 4.
If you use these gestures, you have to give attribution to the owner.
By Sunglass - 4 Years Ago
4u2ges (5/15/2022)
Sample:
Now works, very thanks
