python plug in with iclone 8
https://forum.reallusion.com/Topic513650.aspx
Print Topic | Close Window
By johnsongaric1 - 4 Years Ago
I just upgraded to iclone 8, everything is working great except I can't seem to load my python plug-ins?  Anyone know the secret?
By sungod - 4 Years Ago
think i did read somewhere that all Python  Plugins will need an update from the author eventually to work.
These if done by Reallusion hopefully will be updated.
I am also waiting for some third party plugins to get update
By Podman1000 - 4 Years Ago
I just discoverd that as well.  Bummer.  Now we have to wait again.
By ken_1171 - 4 Years Ago
Why do the plugins need updating? Has the Python version changed in IC8?
By Amper Sand - 4 Years Ago
To share my experience, it was quite a rollercoaster:
Part 1:
I downloaded in IC8 @Data Juggler's Newton's Craddle prop, controlled by Python script.
https://marketplace.reallusion.com/newton's-cradle
It was working well in IC7, however in IC8 the Python script refused to load due to some error, even as I have all iC8 Python support installed. I wrote a message to Data Juggler who, very kind as always, replied immediately telling me he will check - thank you, Data Juggler.
Part 2:
I said "no problem" - so I loaded the prop and script in IC7, ran the script, and recorded animation. I applied the recording to a fresh, non-pythonized prop, everything went OK. Opened the IC8, placed the prop on a new project, but when I applied the recorded animation, the whole prop become packed, like all its sub-props lost their positions. Tried (with a slight hope) motion alignement setting, but no avail. Eventually, the workaround was following:
- created a fres IC7 project with the non-pythonized prop with applied recorded animation.
- opened this IC7 project in IC8 - was working OK this way.
- saved the animated prop as an IC8-one and then applied it to the real project
By Data Juggler - 4 Years Ago
Sorry, IClone 8 broke most of my Python scripts.
I just tried to see if I can fix this, and without documentation or answers from IClone dev team, I am stuck.
The only thing I can suggest is if you have IClone 7, you can animate the prop, and then open it in IClone 8 and it should convert the motions.
I am little frustrated no real documentation, and the one thing they sent me to upgrade isn't very informative.
I started a converter for the scripts, but I don't know all the new features well enough to build it. Reallusion should have done that.
By 4u2ges - 4 Years Ago
In another thread Peter said RL is working hard on documentation release. Hope it would be out soon.
