Troubles with install/uninstall
https://forum.reallusion.com/Topic5128.aspx
Print Topic | Close Window
By briansmacau - 18 Years Ago
G'day
I installed the trial version of Crazy Talk so I could see what it does. Everythin OK so far.
It wont launch and when I try to uninstall it says the programme is running. Someone is lying!
Task Manager says it IS NOT running but Vista will not let me uninstall.
I have an Acer 4520G with Athlon dual core 1.8GHz, 2G RAM, GeForce 8400M graphics.
I would really like to try this with a view to getting the full version.
Any advice?
Ta
beeg
By Peter (RL) - 18 Years Ago
Hi,
I know this may sound obvious but have you restarted your computer and tried to uninstall immediately after. Quite often a restart will allow an uninstall in these situations.
If your problem is still there then you should contact Support who will try to help you. Use the form below to contact them.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
I hope you get this resolved soon.
Finally rebooted (just after the post) and it worked straight off.
Have already ordered the full version.
This thing rocks!
Hope to be here more often.
