Weird poly count import issue (I'm new)
https://forum.reallusion.com/Topic511753.aspx
Print Topic | Close Window
By k_921556 - 4 Years Ago
Hi
I'm incredibly new to 3D design and I'm having a slight issue with poly count while importing.
I am trying to import a simple crop top I made in CLO3D/Marvelous Designer but upon import CC3 is telling me the garment is 1,100,000 poly count?
https://imgur.com/a/ujKYOZu
On the attached screen shot of my garment in CLO3D, you will notice the poly count for the front piece is 15,000. The total for the whole garment is roughly 45,000(I'm having trouble getting the total count in 1 screen shot).
You will also notice the selected triangle count in CC3 is 1,100,000.
Am I misunderstanding poly counts? or is something strange happening here?
Any advice is greatly appreciated, I feel helpless at the moment.
Thanks in advance.
By 4u2ges - 4 Years Ago
Selecting multiple patterns in MD (or CLO) does not give you a sum of face count as one would expect (only one random pattern is picked in properties).
Plus if you export with Thick option it would double the face count for exported garment. Always export Thin and Weld.
Judging by the CC screenshot, the poly-count is right, given dense mesh overall and extreme at the cuffs, collar and bottom.
edit: forgot to quote/tag.
4u2ges (5/5/2022)
Hey,
I had no idea that thick material would double the poly count, I'll definitely be doing thin + weld from now on.
I'm also going to experiment with lowering the particle distance in CLO3D to see if I can find a balance between visual quality and performance.
Thank you very much for your advice, I really appreciate it!
