What is the FBX key and how can I find it?
https://forum.reallusion.com/Topic511638.aspx
Print Topic | Close Window
By hanmo14010817 - 3 Years Ago
HI there, whenever I try to import models to CC3, it tells me to enter a FBX key, which I cannot find no matter what? Can some1 plz kindly tell me how to find it?
Thx
https://forum.reallusion.com/uploads/images/b572a3e7-f947-455d-bd06-16d6.png
By Peter (RL) - 3 Years Ago
Hi...
An FBXKey is generated when you export a character from CC3 to edit in 3rd party tools. Then when you bring the edited character back into CC3 you can enter the FBXKey that was generated on export.
For characters you wish to import like Daz Genesis characters you use Transformer where no FBXKey is required. In addition if you wish t bring in hair, clothing and accessories you can go to Create > Accessory and again you won't need an FBXKey.
By yepkoo - 3 Years Ago
FBXKey; Except for DAZ characters transferred to CC3 with transformer, I guess to avoid transferring characters that are incompatible with CC3 to the program.
CC4 is not supposed to have FBXKey.
By vidi - 3 Years Ago
Has nothing to do with incompatibility , It is necessary to import CC Character back.  That protect the Morph Sliders so you can not use  for unauthorized resale.
e.g You morph a Character and export, change a little bit and you want sell as if it is you own, but that is forbidden. The FBX Key save all information and you can only import if the fbx key fit. If you now make a new slider, the User need all morph there was used. You can not  sell this as a single new morph.
Otherwise export the Character unmorphed and change the geomerty , you can make you own morphsslider  for sell.
CC4 is not supposed to have FBX Key.
 I hope not, because I use for weight painting an another Programm.
Maybe you can be right.
As you said, if that's the purpose of RL, it means nothing more than just causing difficulties for its users.
This should be just a licensing issue in my opinion.
But on the other hand, if you don't have FBXKey, you can import everything.
So how does it work if you import a non-standard character into CC3?
It does not have an infrastructure that supports it like CC4.
Morphs won't work anyway.
It can even cause the program to get confused and crash.
You can only use it in iClone using 3DXChange.
But if CC4 requires FBXKey then you cannot import your non-standard characters.
Then I think they couldn't have made the non-standard characters shown in the CC4 promo videos.
I'm just trying to think logically but I could be wrong.
A Morph is only  a new Geometry based from the same mesh not a new mesh.So you can only sell data that are made by you.That mus be protected.
You can not import an non Standard CC3 Character only morphs
Btw CC4 will be a union from CC3 and 3D xchange , not really a new thing , but better useability.
All the best come toghetter .
Yes, you are right.
This is nothing new.
But it's a huge new feature for CC4.
Because CC3 does not support 3DXChange, so you cannot import your characters.
Maybe the purpose of FBXKey is to protect morphs as you said. But it can also be a precaution as you can't properly import your own specially equipped characters into CC3.
So it's not just morphs I'm talking about.
The CC3 program seems to be 100% dependent on CC characters.
After all, you can also apply morph using iClone.
yepkoo (5/5/2022)
CC4 also uses FBXKey when used in the way I described previously, but you won't use FBXKey when importing non-standard FBX characters into CC4.
It may be right or wrong, I just write in my own opinion;
FBXKey verifies that the imported character is a Standard CC character and maybe includes some settings such as applied morphs.
However, since CC4 has 3DXChange feature, it will not need FBXKey when importing non-standard characters such as the character of the friend who opened the topic.
However, if a non-standard change is made on the CC character, it can still be imported as a non-standard character without using FBXKey.
Since the program knows that this is not a standard character, some of the features we use for standard characters will not be available for non-standard characters.
Of course, I cannot guess to what extent these limitations are.
Frankly, I searched the forum site and could not find a clear answer from any official about FBXKey, which everyone has been trying to make sense of for years.
By animagic - 3 Years Ago
I don't understand what is so hard about the FBX key...:unsure:
By visionarymind111 - 3 Years Ago
What is so hard about it? Let me give you an example:
1) Create a new character in CC3
2) Import that character / convert in CC4
2) Export character as .FBX
3) CC4 doesn't include .fbxkey (embedded)
So once you have converted a CC3 character to CC4, there is no going back. Say you are working with partners (as we do) that don't yet have CC4. You are out of luck if you have made extensive changes to their CC3 characters. There is no way back, not via .iAvatar, not via .FBX.
I presume Reallusion never thought of this scenario. Or quite the contrary --- they are well aware and just trying to heavy-arm people into purchasing CC4. I will tell you this, as a result of this "problem", we are likely moving away from Reallusion altogether.
Need more explanation?
visionarymind111 (7/8/2022)
It has been explained many, many times on the forum over many years that once a character is saved in a newer version it can't then be taken back to an older version. This isn't new with CC4. This has been the case with every version of iClone and every version of Character Creator (and also Cartoon Animator).
I don't think it's just about fbx.key.
In CC4, new features can be defined to the character and CC3 may not see these features or crash.
Many programs, not just CC, will not open older version files.
However, I don't know if it will be difficult as a solution, but the export option can be added to old versions. For example, exporting a word file compatible with old version office programs.
Of course, I don't know if this is possible.
However, I don't think the same thing for the live link we set up with CA4.
Because this link just imitates animations.
If iC8 Live Link works with UE4 and UE5, I think CA4's plugin will also work with a minor update.
As yepkoo points out, many software programs (not just iClone or CC) will not open items created in newer versions. So this is not about strong-arming anybody...:unsure:
By michaelrbarton - 3 Years Ago
Did you save the CC3 project? Did you make a copy of the CC3 avatar before sending it to CC4? You have to be responsible to backup your creations.
