Failed to apply materials. Materials are not compatible with this object
https://forum.reallusion.com/Topic510844.aspx
Print Topic | Close Window
By esemgee - 4 Years Ago
Am sure this must have cropped up before but can't seem to find a link in the Forum, though Google did give me something which I didn't understand:
 This error indicates that you were applying iMtlPlus to an unmatched object. To apply iMtlPlus, first you need to select the corresponding object which has the same mesh name and material name.  For example, double click dress (FADSDB_F_Dress_A_L) first then apply .imtlplus with the same name (FADSDB_F_Dress_A_L) for it..
So, my problem is simple. I want to add some hair to an avatar, any avatar, just like I have done for years. The particular hair is Curly&Afro by Dorothy Jean Thompson, 2021 and even with the default  C3+ avatar we get on loading I get 'Failed to apply materials. Materials are not compatible with this object'. Other hair also gets this message. The only hair that works is going back years, to iClone 5. Something seems to have changed in my set up as all this used to be a doddle. How come things are now unmatched???
By jeff.davies - 4 Years Ago
In my experience, this generally happens because I'm trying to apply a materials to a model that is different than that the materials is created for. This happens alot for me when I buy packs of something, like hair. The materials are not interchangeable. If I mistakenly grab the wrong material and drop it on the model, I will get that message.This is even true if you drop a "left sided" material onto the "right-sided" model (think of a pony tail falling on either the left or right side of the model).
- Jeff
Damn. Was hoping somebody had an answer. I know what the problem is but I can't find a solution. Basically, as of now my CC3 is useless. I can't create anything thanks to an error I have never, ever had suddenly appearing. Don't tell me I have to reinstall again!!!!
By sungod - 4 Years Ago
I will post my experience within this weekend, if you don't get reply. I might have that hair.
By bossdeff - 4 Years Ago
i am also having this problem, I installed CC4 and then deleted it cos i couldn't use it with i clone 7, so now i cannot use hair/beard builder, says I'm using an incompatible character lol. The default character. even tried using a generated character using Headshot. same issue. I've reinstalled. no fix so far. and then I find this post, where this guy also has not received any help in over a MONTH!.
By SyrDoN - 4 Years Ago
are you applying the variations or the hairgroup?   You hve to apply the hairgroup first and then choose from the hairstyles
2 folders under each new pack.   one is hair.  it contains the hairgroup.  apply this.   the stage has variations that can be applied after.
By wires - 4 Years Ago
bossdeff (5/26/2022)
This is a user Forum and not a support area. The best place to get expert help is by contacting Reallusion Support directly, posting the issue in the Feedback Tracker as it is monitored by Reallusion staff.
By R Ham - 2 Years Ago
I think you're wrong, Gerry. The Forum is the exact right place to ask this question.
By animagic - 2 Years Ago
R Ham (1/1/2024)
I just noticed that you're responding to a post of more than two years ago. But Gerry has a point, regardless.
You can ask a question here, but if it is very specific and technical, you may not get an answer. This upsets some people. Or they may not like the answer and get angry. It happens...:unsure:
animagic (1/1/2024)
R Ham (1/1/2024)
You can ask the question but may not get an answer, which upsets some people. Or, they don't like the answer and get angry. It happens...:unsure:
The post Gerry is responding to seems to be quite specific and technical and also lacks details. Deleting CC4? Does the poster mean uninstalling? Deleting software is bound to cause problems.
I was an engineering tech writer when "the investors" sold us and I found I was suddenly in Marketing. I remember the meeting where the Mktg Dir said to me, in front of everybody, "We can discontinue the manual, and instead give them a forum and they can answer their own questions." And so they did.
So, I couldn't avoid posting a reply.
R Ham (1/1/2024)
animagic (1/1/2024)
R Ham (1/1/2024)
Fair enough... And how did that work out?
animagic (1/1/2024)
Poorly, for me, if that's what you mean.
R Ham (1/1/2024)
animagic (1/1/2024)
I meant for the company....:unsure:
By Rampa - 2 Years Ago
I hope the OP solved this two years ago. Their initial post actually had the solution right in it. Just in case anyone is having trouble trying to apply imtlplus files, they are made for specific meshes. So in my example below, I load the Choya hair, then the Choya_Hair_04.imtlplus. The imtlplus files are not compatible with any mesh, like mtl files would be, and can only be applied to the mesh they were made for. You will see imtlplus files for both hair and clothing color variations.
https://forum.reallusion.com/uploads/images/5734d1e3-df9c-4269-b96e-9778.jpg
animagic (1/2/2024)
The company I worked for disappeared almost overnight. The buyer was only after the unique database. Since then I have seen the "no docs" approach repeated many times.
Rampa (1/2/2024)
It was this question that drew me to this thread. I didn't know what they were for. Thank you.
