Problem with materials of obj files in 3DXchange
https://forum.reallusion.com/Topic510232.aspx
Print Topic | Close Window
By Cary B - 3 Years Ago
I used to export props from DAZ into obj files, then bring them into 3DX and convert them to Iprops, a fairly simple process.
Now when I attempt this, however, I get an OBJ with no texture files. They don't show up, though the mtl files are exported into the same folder with the obj files.
Is this some kind of path problem, or maybe a DAZ setting that is different? Does anyone know? Thanks.
By animagic - 3 Years Ago
First thing to do would be to check the path that is specified in the MTL file. I have had to correct that (not with DAZ, but in general).
I'm no expert, but I believe Mike Kelley recommends to export props as FBX, so that's something else to try.
