By ferrarielly - 18 Years Ago
Hi,
I have an image with 3,4 puppets and I need to animate all their mouths...
Is that possibile with this software? How?
If not, is there any other software that can do that?
Thanx Elly
By Popeye - 18 Years Ago
Hi elly
Which software are you referring to iClone or Crazy talk?
Crazytalk;)
I am not an expert on this software but I think the best way to do what you trying to do is to make a animated gif of the other puppets and then bring these onto the timeline under SFX. I assume you are using Version 5. If so look at the projects already in it. The one with the boy talking about using Crazy talk in the classrooom is a good example.
Like I said I am not an expert at this and other people may give you better advice.
Good luck
Regards Popeye
ok thanx I'll try.. ;)
Do you know any other software to do so?
Thanx
I do believe Crazy talk :)
By tihs1313 - 18 Years Ago
The only way I can think of is to animate each separately with a green screen background and then export them into a video editing program like final cut or after effects. Once there key out the background and add your stage scene. Of course timing 4 will be a challenge. Sorry I couldn't think of anything easier but Crazy Talk as far as I can tell just does one at a time. Good Luck
By Rainman - 18 Years Ago
As mentioned above by tihs1313 you can achieve this effect rather simply using most any video editor by utilization of the green screen effect.
I did this without much difficulty during the CT5 beta testing phase: http://www.walmarko.com/TheWall.wmv
Unfortunately, this was created before I had viewed the CT5 tutorials, and gained better knowledge of the abilities of CT5 which is quite powerful once you spend a little time learning the latest capabilities. Nonetheless, the green screen/chroma key function would need to be applied regardless.
I used Magix video editor for the clip which is very simplistic in performing green screen.
Hope this helps,
