outdated support for importing sketchup files
https://forum.reallusion.com/Topic509317.aspx
Print Topic | Close Window
By Darren01 - 4 Years Ago
I have 3DXchange 7.81 PRO
I usually get a lot of my props from Google 3D Warehouse. There is even a direct link in 3DXchange to Google 3D Warehouse.
Problem is, it will only import skp files in 2015 format or earlier.
3D Warehouse only offers downloads as early as 2019 skp format.
I used to get around that by loading the props into Sketchup first and then converting the props back to an earlier version.
But now Sketchup won't save the file anything earlier than 2019 either.
So in a nutshell, I can no longer use the Google 3D Warehouse.
Is there a reason why RL hasn't updated 3DXchange with the ability to import current SKP files ? Or am I missing something?
It's really going to restrict where I can source my props now......
By animagic - 4 Years Ago
pCon.planner will import SKP files and export them as FBX or OBJ.
By wires - 4 Years Ago
Adding to what animagic posted, you can also export files from pCon.planner in Sketchup 2013 and these can be edited in 3DXchange if required.
By Rampa - 4 Years Ago
See here for importing the current SKP files:
https://kb.reallusion.com/Product/52850/How-To-Import-Files-From-3D-Warehouse-Into-3DXchange
By michaelrbarton - 4 Years Ago
There is an online 3D converter called AnyConverter. I use it a lot of times to convert files.
Convert SKP to OBJ online for free - AnyConv
thanks guys, I'm glad there is a work around this.
I like to support our developers in the Marketplace as much as possible, but the 3D warehouse is good for some of those random props or when the budget is a bit limited
