SMART GALLERY
https://forum.reallusion.com/Topic509031.aspx
Print Topic | Close Window
By donnaklewer_943564 - 4 Years Ago
Hi!   I can't find/install smart gallery.  I had it with lots of stuff, then I had to un/reinstall iclone in order to change computers.  It doesn't show up in any menu for project or the hub.  I downloaded it again, and it went into a folder that isn't accessible to iclone.   THANK YOU SO MUCH for all your help!
By jeff.davies - 4 Years Ago
It should be under one of the main menu items like View, Window, etc. I'm going from memory here as I'm about to jump on a call, but I'd start your search there.
By yepkoo - 4 Years Ago
You can try to download it separately from the link below.
https://www.reallusion.com/smartgallery/default.html#free_download
Smart Gallery should appear installed as follows.
https://forum.reallusion.com/uploads/images/903f6b9a-fac0-4967-a939-9f3f.jpg
If it is installed and does not appear in your program, you can activate it as in the picture.
Shift + F4
https://forum.reallusion.com/uploads/images/68adf7b3-1267-4eec-9882-c58f.jpg
Thank you, I've been away.  Unfortunately, Smart Gallery doesn't show up in any of the iclone menus or on my Reallusion hub.  It only shows up in character creator, and  it doesn't have any of the material, lighting, background, etc., stuff I had downloaded through the years as well as any current options.  I don't know if this is because it's not in iClone, but it isn't under stage either.   I had to uninstall this summer to switch to a  computer with more memory, and now I can't open any of the stage sets I made before.  I can still access the characters fortunately, and they are dressed in the clothes that I had before.... but, none of the previous  props are available in any programs either.
Thank you so much for any help you can offer.  You are appreciated for listening, even if you don't know the answer!
