Rendering Quality Problem In Iclone 7
https://forum.reallusion.com/Topic508709.aspx
Print Topic | Close Window
By tez553 - 3 Years Ago
Hi,
I have been creating simple short one character talking scenes (Like crazy talk8) using auxiliary in Iclone 7.
The problem is when I render an image or video the characters skin appears darker (see images below), I would like to keep the brightness when rendering how can I do that? Thanks
Left Image from Iclone
Right image after rendering
https://forum.reallusion.com/uploads/images/3163e58d-5a2c-4c5c-9dbd-194a.jpghttps://forum.reallusion.com/uploads/images/c15de0a7-964d-4fc5-9dfb-86fb.jpg
By wires - 3 Years Ago
The auxiliary light in iClone is only there to help users set up dark scenes without messing around with their carefully adjusted light settings. It does not render out in any image or video. To correctly view your scene before rendering turn it off and adjust the various lights that you have active to achieve the result that you require.
By AutoDidact - 3 Years Ago
tez553 (3/14/2022)
Hi,
Well the left image has no cast shadows, as the right one  is receiving shadows from the hair.
