How do i create vampire fang in CC3?
https://forum.reallusion.com/Topic507467.aspx
Print Topic | Close Window
By Stridgamer - 3 Years Ago
And I also thinking I missing some sliders as well!
Need help
Thank you in advance!
By yepkoo - 3 Years Ago
If you type "Canine Teeth" in the search, you can see the vampire teeth for the upper and lower teeth. (But it may belong to the headshot)
The other option is to buy the one sold in the market.
https://marketplace.reallusion.com/vampire---skingen
The third way is if you have 3DCoat or ZBrush program, you can make your own vampire teeth.
In the video below, I made a vampire tooth in 3 minutes now.
Hmm i don't have "Headshot"
And for the second option i tried but i think missing something!
For the 3rd one i have not tested! Maybe i will do later in the future!
But i will get Headshot next month!
"If you type "Canine Teeth" in the search, you can see the vampire teeth for the upper and lower teeth. (But it may belong to the headshot)
In the video below, I made a vampire tooth in 3 minutes now."
By Rampa - 3 Years Ago
If you have CC3 Pipeline, you have mesh editing tools that make it pretty easy.
Select the teeth.
Click the edit mesh in the Modify panel.
Select the "Element" tab.
Click one canine tooth, then hold down CNYTL and click on the other.
Select the scale gizmo.
Scale the selection on Z to elongate the teeth.
https://forum.reallusion.com/uploads/images/919b6290-9a9a-4409-8a28-78e2.png
Well I just bought it today!
It kinda works!
