Launch External Image editor wont work....its blanked out
https://forum.reallusion.com/Topic507160.aspx
Print Topic | Close Window
By bootysaur - 4 Years Ago
https://forum.reallusion.com/uploads/images/ac8cfbb2-6e6a-4fa0-888c-850c.pngwwhat am i doing wrong i want to build a character in photoshop
By Peter (RL) - 4 Years Ago
Hi...
Your screenshot shows you don't have anything selected. If you select for example RArm_Layer in Layer Manager then the "Launch External Image Editor" button will become active.
even when i select anything it wont work, isn't it supposed to launch the whole dummy character. Also doesn't let me select the entire character. If I shift select in the scene manager it only launches one body part.https://forum.reallusion.com/uploads/images/9a797db6-eaf2-43bd-b42b-3581.png
No ""Launch External Image Editor"" is intended for a selected sprite editing. If you want to export the whole character to Photoshop, and you have the Pipeline version of Cartoon Animator 4, then you can select "Launch PSD Editor" from the same side toolbar. This will then open the character in Photoshop where you can change the sprites to your own custom images.
ooooooOOOOOOOOOH ok so i have to upgrade form pipeline from pro or is this a downgrade?
bootysaur (2/18/2022)
If you currently have Cartoon Animator 4 Pro you can still create custom chracters but you do it in CTA4 itself rather than in Photoshop.
Please take look at the tutorial below which explains the process.
Cartoon Animator 4 Tutorial - Character Creation with G3 Template
https://www.youtube.com/watch?v=kN-mKg5KlmM
