By masternihilus95 - 4 Years Ago
Hey I was create a character in Daz. I imported it to CC and working on it. I was use scales pattern after few moves I see these scales are blurry. I don't have any layers in skin editor. It's any solution for this? to get unblurry or recreate my layers? :(
By Peter (RL) - 4 Years Ago
Hi...
Check your texture setting in SkinGen to make sure it isn't set different from your general texture settings in CC3.
So for example, if you are using 4K textures, and the "Max Texture Size" setting in your CC3 Preferences (CTRL+P) is set to 4K, but in SkinGen it is only set to 1K then you will notice the skin look blurrier when you activate SkinGen. If you set them both the same then you shouldn't notice the textures looking blurrier in the SkinGen Editor.
Hey! Thank you for reply. I solved this problem. I was have the normal mask from old tattoo, when I delete it everything is HQ and okay.
Thanks
