Photoshop issue
Home
Archive
Character Creator 3
Technical Issues
https://forum.reallusion.com/Topic506178.aspx
Print Topic
Close Window
By ramiong18
4 Years Ago
Hi, I tried "Run texture" with cc3 but my photoshop opens in a freeze state. I can't click anything, the login window is also visible, but also frozen.
I use photoshp all the time but these problems only occur when opening with cc3.
By yepkoo
4 Years Ago
Yes, I've had this problem a lot.
It was fixed after formatting.
It actually works if you wait a long time.
Another method is to open Photoshop beforehand and keep it ready.
By toystorylab
4 Years Ago
Yeah, open Photoshop beforehand...
It's annoying as I sometimes forget it and then the mess starts.
The same with iClone...
Maybe generally run as administrator (you can set so) is also a workaround.
By Wacky-Wabbit
4 Years Ago
I never had that problem with previous versions of Iclone and CC. However, after upgrading to Iclone 7 and CC3, I started to have the problem. I wasn't sure what was going on. But I could open my Photoshop PS5 (at the time) outside of Iclone and CC3. It was sort of a "handicap" for me. I tried everything to get PS5 to launch via those programs. But it never would launch correctly. I ended up purchasing Photoshop Elements 15 (at the time). I installed it, reconfigured my Iclone 7 to launch PSE 15 as my texture editor, and lo-and-behold, it worked. So, I did the same thing with CC3, and it worked fine. I still have PS5 on my computer but I don't really it use it that much. My main go to program is PSE 15.
Another that help to prompt me toward PSE 15 (at the time), was that I could no longer launch an installed filter/editor program "Filter Forge" after the company upgraded the program. It would no longer launch in PS5. Their customer support let me know that I had to upgrade to a different version of Photoshop, as the program could no longer be launched from PS5. I didn't want to spend the money on PS6, so I chose as less expensive option, Photoshop Elements 15 (at the time), which worked great! So, that one editor change took care of all my editor-related issues.
I'm not saying that to say that it will fix your issues. Just letting you know what the change did for me.
