Prop Combinations saving as 1?
https://forum.reallusion.com/Topic506140.aspx
Print Topic | Close Window
By MaxxPowr - 4 Years Ago
Hi,
I'm newish to I7. I'm used to using Poser.
I created a little cone hat, using the cone prop.
I then parented a cloth prop to the cone prop.
When I save the Cone Prop (hopefully to save the combination) it only saves the cone prop.
I'd like to save the combination of Cone and Cloth as 1 prop.
Is that not possible in I7?
Thanks!
By animagic - 4 Years Ago
Make sure to use Attach and not Link for the cloth prop. You can check in the Scene Manager if the cloth prop hangs underneath the cone prop.
Thank you so much.
