Blender mesh crashing CC3
https://forum.reallusion.com/Topic504417.aspx
Print Topic | Close Window
By stevew - 3 Years Ago
Hi guys.
I have created some hair in blender ( attached ). Exported the selection as obj.
In CC3 I create material and load in the obj and it crashes CC3.
Any ideas please.
PS cant upload the file. Forum states :
Sorry you have already exceeded your available space or this upload would cause you to exceed your available space. zip file is 55kb
By 4u2ges - 3 Years Ago
You'd probably have to delete some past attachments at your profile (the limit is 10Mb)
Or use some cloud service to share your file.
deleted some attachment thanks.
It has 0 faces. And CC cannot take such a mesh. Looks like you made some particle hair in Blender, but they would not work well in CC anyway.
I never dealt with particle hair in Blender, but there probably a way to solidify them at source.
Otherwise, you can try to extrude all vertices with some low value like 0.001 to create thin strips.
Or get more sophisticated - convert it to curve, bevel with built-in square profile and then use another curve (like a path) and apply it as taper to make a thin pyramid shape so it looks like a thin hair.
Bottom line, that object has to have faces, otherwise CC would keep crashing. And scale it to 100 when exporting from Blender.
