By wintoons - 4 Years Ago
Hi, Wanted to know, what is the default frame rate for iclone 7? Is it 60FPS? Also, can you change it? Just curious.
By michaelrbarton - 4 Years Ago
Yes you can. Just go to render, then on top is photo and video. Photo sequence gives you the option to change frame rate. Video gives you 3 options, 30 (default) 24 and 60. I hope this helps. Good luck.
