cc3 in windows 11
https://forum.reallusion.com/Topic504219.aspx
Print Topic | Close Window
By Mikie123 - 3 Years Ago
I did get all my refunds.  Do you have a version of cc3 that works with windows 11.  A trial.  If I could get it to work I would give you the money back.
By sungod - 3 Years Ago
CC3 is working for me with windows 11 latest version just fine.
I have had trouble with it for about 3 years.  Could you give me an explicit explanation on how you did it?  Maybe a video.  Thanks.
By yepkoo - 3 Years Ago
It's been 3 months since Windows 11 came out and I've been using it without any problems since it came out.
There are quite a few people using Windows 11.
You don't need a tutorial for this, you just install the programs via the HUB.
The problem you are experiencing may be your drivers or one of your hardware that is incompatible with Windows 11.
Also, if you haven't done a clean install, you're likely to run into problems
By animagic - 3 Years Ago
Mikie123 (1/12/2022)
Maybe I'm misunderstanding, but how could you have trouble with CC3 on Windows 11 for three years?
Or if you mean Windows 10, there is a system-related problem that will not go away with Windows 11.
