By Chance Chi - 4 Years Ago
Hello! There is a new bug after updating to the newest version 4.51.3511.1 . When I import the voice file in WAV format, it can't show the waveform. This wasn't an issue in the earlier version.
By Peter (RL) - 4 Years Ago
Hi...
Are you using the Windows or Mac version?
I just tried a few wav files in the Windows version of 4.51.3511.1 and the waveform displays correctly (see below).
If you are using the Windows version, then it may be a problem with the wav file itself. Perhaps you could share your wav file so we can test it.
Thanks for your reply. My CTA is Windows version. I test my wav files again. Some of them can be showed their waveform. Some of them can not. I found that the wav files made from Audacity aren't showed the waveform in CTA. And I try to upload a wav file here, but the forum doesn't allow uploading this kind of format.
By animagic - 4 Years Ago
Make sure you export from Audacity as 16-bits wave and either 44.1 or 48 kHz.
You point out the issue. Thank you very much.
