Kubold's Female Animset Pro - T Pose
https://forum.reallusion.com/Topic500863.aspx
Print Topic | Close Window
By lubmir2k - 5 Years Ago
Hello, I just got this asset from the Unity Asset Store - Female Movement Animset Pro | 3D Animations | Unity Asset Store. When trying to import animations to iClone via 3DXchange, the profile is right (Maya Human-IK), however, T-Pose is incorrect.
Anyone know how to solve this?
Thanks.
By Peter (RL) - 5 Years Ago
Hi...
Have you tried loading the Maya Human-IK T-Pose (see below). Many standard T-Poses are supplied with 3DXchange so this may help.
https://forum.reallusion.com/uploads/images/f2a7d950-48b1-4260-a891-99c3.jpg
Hi, thanks for a quick response, Maya-IK gets me an exactly same result that I've posted. I tried all T-Poses from C:\Program Files (x86)\Reallusion\iClone 3DXchange 7\3DX template\TPose, but no success.
Thanks for updating us.
If you don't have a suitable T-Pose then you may need to create one. Please take a look at the tutorial below. It's an oldie but still relevant in this situation.
Converting External Motions without a Preset T-Pose
https://youtu.be/6ZoPf6yMf1Q
By Amper Sand - 5 Years Ago
@Peter, such bones alignment for a T-Pose cannot be done programatically, ie a button for the end user? Bottom line, it's pretty mathematical, lol, coordinates, therefore suitable for such tool.
By 4u2ges - 5 Years Ago
ampertox (11/27/2021)
Unfortunately it is virtually impossible. There is no standard armature structure and bones naming convention. It would vary from one source to another.
If you are lucky, a T-pose would be the at the first frame of the motion. If not, then little extra work would require.
But setting up a T-pose in 3D Exchange from some odd pose is no joy at all and is unnecessary.
Good news is that motions have a rest pose which is not visible in 3DX (very unfortunate).
So the goal is to extract that rest pose. Rest pose is set to T-pose most of the time (or at least to some sort of symmetrical pose, which is easy to convert to a T-pose, even in 3DX).
Easiest way is go through Blender. This has to be done only once for the set of motions you acquired from a specific vendor.
* Import one of the acquired BVH file into Blender
* Go to Object Data Properties (an icon with running human) and switch to the Rest Pose
* If you are in luck, then the pose would be a T-pose. If not, it would still be some sort of symmetrical pose, which is easy to tweak to a T-pose in Edit mode.
* Switch to Pose Mode. Ctrl+A > Apply Pose as Rest Pose (if you tweaked it in Edit Mode).
* Export as BVH, frames 1 to 1
* Open exported pose in 3DX, set X rotation to 270 and convert to Non-Standard
* Save T-pose and 3DX profiles
* Finally load motions one by one and use 2 saved profiles (T-pose and 3DX) to convert them to iMotion.
Thanks, with your help I achieved what I was looking for. It's not perfect, but it's good enough.
