Adding a "perform" motion silences the audio? Is this normal/
https://forum.reallusion.com/Topic498109.aspx
Print Topic | Close Window
By jfjs75 - 4 Years Ago
I have the Conversations Mood 2 pack, and want to use it in an animation, but whenever I add it, it silences the audio (and even the audio that comes after it is gone.... which, is a problem cause I need the audio to be able to sync my motions to it.
Why does it silence the audio, and is there a way to stop it from doing that?
By Peter (RL) - 4 Years Ago
Which audio do you mean? If you mean the voice for the character then this should be added after applying the Conversation Perform motion because Perform clips replace the voice track..
When planning your scenes it's important to remember how the different type of animation clips work in Cartoon Animator to avoid problems. Motion clips affect the body only (so won't affect the audio), Face clips affect the face only and include a voice track, and Perform Clips include body, facial animation and a voice track.
