Deleting timeline keyframes
https://forum.reallusion.com/Topic497913.aspx
Print Topic | Close Window
By Maxxscape! - 4 Years Ago
Is there a way to delete frames and keep the current x,y,z,h,w, etc of what is left?
Example, say I have created a video that is 1000 frames
Next, I want to remove frames 1-999 and keep the frame 1000 'information' which would now be at frame 1
In other words, if me character moved from the right side to the left, I want his to be exactly the same (positions, sprites, etc) and any other props, etc. that may or may not have moved or changed and then use that as a starting point for the next project.
Can this be done?  Is there a button that wold freeze frame everything ?
or maybe not delete frame one since that is where everything gets initially set and props imported, etc.
Thanks
James
By animagic - 4 Years Ago
I think this is what you are looking for:
https://forum.reallusion.com/uploads/images/30d53dce-c1a9-4eb7-9d6a-b4d9.png
This will allow you to freeze the action at the first, the last, or the current frame.
Apologies - I thought I was posting under the Cartoon Animator topic.
