OMNIVERSE won't launch
https://forum.reallusion.com/Topic495130.aspx
Print Topic | Close Window
By mtakerkart - 5 Years Ago
I get an 3060 rtx card yesterday , the driver are up to date but the Omniverse launcher said :
"required driver for omniverse compatibility"
What did I not understand ?? :ermm:
https://forum.reallusion.com/uploads/images/5e490c2e-84db-45e4-93ee-2f02.jpg
https://forum.reallusion.com/uploads/images/cf519d0b-fd06-49bc-b7f1-092e.jpg
By StyleMarshal - 5 Years Ago
First update all the green bells.
Do you have 2 GPUs installed ?
Thank you Basseline
The update will take some time.
Interesting question about the GPU. I have only the 3060 on my computer . I put in the same slot
of my Geforce GTX 1070 and if I read the log file it is said :
"2021-09-20 20:02:14 [13,206ms] [Info] [carb] Initializing plugin: carb.graphicsmux.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9]) (impl: carb.graphicsmux.plugin)
2021-09-20 20:02:14 [13,354ms] [Warning] [gpu.foundation] Skipping unsupported non-RTX GPU: NVIDIA GeForce GTX 1070
2021-09-20 20:02:14 [13,354ms] [Info] [gpu.foundation] "
Is it possible because I put it on the same slot so my pc think it's my old card ??
no , but better you do a complete deinstall of all the Nvidia drivers before installing the new one.... there is a Nvidia deinstaller , do a google search and you will find :)
I guess it is called DDU .... Display Driver Uninstaller.
I did it ,  reinstall everything same issue...
But the log launcher says that at the end:
"[2021-09-21 19:36:48.287] [error] (node:11260) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron.  See https://github.com/electron/electron/issues/23506 for more information
[2021-09-21 19:36:48.604] [info] Logged in.
[2021-09-21 19:36:48.690] [info] Running production web server.
[2021-09-21 19:36:48.696] [info] HTTP endpoints listening at http://localhost:33480
[2021-09-21 19:36:48.842] [error] (node:11260) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron.  See https://github.com/electron/electron/issues/23506 for more information"
went to the github but incomprehensible to me ...
I'm not going to get too mad because omniverse is in beta for now but I knew it was going to be a lot of trouble
By charly Rama - 5 Years Ago
I have the same card, I uninstalled all reinstalled all by Geforce experence game ready machin chose and everything was fine. Hope the same for you. Bon courage mon pote :)
Thank you Charly but I re-did a clean re-installation with geforce experience and same problem.
I would do a complete re-install of my computer as I haven't done it in years. However I have not yet finished my clip for the aculips contest, I will do that after.
I sincerely hope that it is a software problem and not a problem with my card ...
The RTX works perfectly with UDK 4.26. I was able to create a wall / mirror without problem.
It will be the big challenge of Omniverse to work whatever the
hardware configuration as long as you have an rtx card...
https://forum.reallusion.com/uploads/images/b56224b7-722f-4dc9-856c-8b19.jpg
By rosuckmedia - 5 Years Ago
@mtakerkart,
Congratulations on your new card,
I have reinstalled Omniverse yesterday,
had previously uninstalled all old drivers with DDU.
In safe mode. But still have the same error.
With the driver. I can start the luncher but somehow,
does not work with the AudiaFace 2.
I also do not know exactly what I have to enter here.
https://forum.reallusion.com/uploads/images/b25688e7-8c94-4cff-aee4-52c0.png
Have uninstalled Omniverse again
will start today a new attempt.(Reinstallation.)
Greetings rosuckmedia
