Creat path for two characters walking side by side
https://forum.reallusion.com/Topic494758.aspx
Print Topic | Close Window
By johnschneider066 - 5 Years Ago
To have two characters walking side by side, can they use the same path or do you suggest two parallel paths?
By mark - 5 Years Ago
I've had good results with one path and attaching a Dummy prop to the path. Then linking the avatars to that Dummy prop. You'll need to tweak the speed of the walks for each avatar and the speed that the dummy moves along the path but that has worked good for me.
In case you are still interested here's a quick tutorial on my down and dirty technique for getting two avatar's to walk side by side using one path.
That’s awesome! Can’t wait to try it myself now. Thank you so much!
Another quick experiment with two different-sized avatar's on the same Path. Still have foot-sliding but I guess I've seen worse...
Thank you so much. Got it now. Used the dummie and it worked great! Saves a lot f time too.
Wow! Ya mean it actually worked??? :P:D
