Removing screen elements for Chroma Keying
https://forum.reallusion.com/Topic494556.aspx
Print Topic | Close Window
By CYBL - 5 Years Ago
How do I remove these two elements from STAGE MODE so I can use my project with MotionLive2D in a live stream without having to do some crazy cropping in my streaming application?
https://forum.reallusion.com/uploads/images/53313b06-82dc-4e9a-b520-d21e.png
1. Bounding box / Render Area (Not required when using window capture
2. The root "crosshairs"
By kylelee - 5 Years Ago
CYBL (9/14/2021)
Hi,
1. You can press F12 as a full-screen mode which will be hidden.
2. The Root crosshair, you could press Ctrl + A  to disable the gizmo.
