Exporting FBX or Add motion plus to 3DXchange failing when having Create Script / Audio File to do facial animation
https://forum.reallusion.com/Topic494503.aspx
Print Topic | Close Window
By kinetikavfx - 5 Years Ago
Hello i really need some help here to find a workaround.
I have created a animation in Iclone with a motion clip, some facial mocap using a iphone, and the viseme animation with a audio file.
The problem is when i try to export a FBX or to add Motion Plus to 3DXchange, it fails, cant be done, some application error is happening and It cant be done.
For my testing i found it is because of the audio file, but it is linked to the viseme animation, if i delete it, then the export will be complete no problem, but i lose all of the viseme animation.
How can i get around this? How can i delete the audio file without losing all of my viseme to be exported.
