By Jeffster The Mighty - 3 Years Ago
Here it is. It seems to happen the first time I add a brow, but it never happened before
By planetstardragon - 3 Years Ago
Have you tried clearing your cache ?
this often happens to me, and I've found it's because of old cache data
go to your "Preferences" panel, scroll down to the "dynamic editor" section....you'll find a "clear cache" button, click it to clear your cache - and problem should be fixed. - if not, try shutting down the program, restarting - then clearing cache ....this is to avoid having the system lock on to incorrect data in ram.
I figured it out. I can't pick eyebrows from makeup. It has to be from the brow builder if the character is other than white.
I'll give that a shot. Thanks
But the major problem here is that the single African American female CC+ option we have has no eyebrows by default
