By panier.garnier - 4 Years Ago
Hello everyone,
I have several motion clips in my timeline and I'm looking for a way to export a list of the first and last keyframes each clip to a .json file. The idea would then to automatically import and trim the clips in Blender using a custom python script. The issue is I can't find a way to retrieve data about keyframes using python in Iclone. I read about the RKey GetTime function here : https://wiki.reallusion.com/IC_Python_API:RLPy_RKey, but I can't find a way to get it to work properly...
Would anyone have any idea how to make use of this GetTime function by any chance ? Or maybe have some clue about how to get infos about keyframes in the timeline ?
Thank you very much for your time and help,
P
By videodv - 4 Years Ago
Hi You may want to have a look at the following link to the iclone page on github and see if this helps Look Here
Chris.
Hi Chris,
Thank you for your message. I had a look at the samples you shared and unfortunately it doesn't really help for my purpose...
I think the infos I'm looking for are stored somewhere in the RIClip data (here : http://wiki.reallusion.com/IC_Python_API:RLPy_RIClip). By removing the clip length from the last keyframe, I should be able to find the start frame for each clip. I managed to find the clip length with "clip.GetLength()" but everytime I try to get the last keyframe ( clip.GetLastKeyTime() ) it gives back a value of 0. I'm a bit clueless on how to get this function to work. Would you have any idea ?
P
