By swablu217 - 3 Years Ago
Hello fellow Reallusion Members, I'm new to Reallusion and in the process of learning. There's a problem and I don't know how to fix it, and it'd be great if I could get some help. I've applied a hair patch "Hair Builder > Rear > Undercut fade" to my model (it has been made with headshot plug-in) and the result came out half-and-half. It seems like the left side of the hair isn't coming out properly, so I tried to fix it with "Modify > Edit Mesh > Vertex" but I failed to make it even. but it got worse. Does anyone know why this is happening and how to fix this?
By 4u2ges - 3 Years Ago
Sculp_Male and Undercut Fade are intersecting. Transform it instead of Mesh Edit.
Load Undercut Fade fresh and select it. In Modify panel go to Transform section. Check Lock Scale XYZ. Then start adding Up value to Scale X. When you reach ~ 100.7, the patch should be raised enough above Sculp_Male mesh and intersection would be cleared. You can also scale down Sculp_Male in Morphs section a bit. There are some sliders including Scale Morph.
But honestly, I am not sure if you even need that Sculp_Male cover. Unless you are adding some other patches to cover it at the top.
Oh yeah... and Welcome
