By nguyenhoang.28071979 - 5 Years Ago
I'm a beginner to HeadShot! I try to build virtual models based on myself! HeadShot is great with editing the smallest details! However, it will be much less laborious if you can catch more perspectives on the left or right side of the character! This feature is similar to Blender's FaceBuilder! I didn't expect to be able to use too many of them! It's great to be updated with more tilt angles! Will Reallusion further develop this feature? Thank!
By Peter (RL) - 5 Years Ago
Hi...
Thanks for the suggestion.
At the moment Headshot only supports a single front facing photo. For now you can use a side profile image for reference purposes as explained in the tutorial HERE.
Support for side profile images is a common request but there is no news as yet as to whether this will be implemented. However, if it is to be implemented it needs to work flawlessly. It will be no good allowing the use of side profile images if you end up needing to tweak more settings than you currently do. This was a problem we encountered with CrazyTalk 8 which required a lot of work to use side facing images. This would defeat the whole purpose of Headshot.
Thanks for the reply! Hopefully in the future we will have more updates!
