By woody173 - 5 Years Ago
Hi I have been trying to use destructible props in my project and after a lot of help from people like Rampa (Thanks Guys) I have hit a brick wall because i keep getting an error message. I even tried to simplify my project in various ways and taking the destructible chair out and replacing it with a standard chair and the same message appears....Any Ideas would be really appreciated
By Peter (RL) - 5 Years Ago
Hi...
There can be many reasons for a "memory could not be read" error message, but commonly this is caused by an object in your scene that is not playing nice with iClone.
Sadly it is not easy to quickly diagnose which one and it normally has to be done using trial and error by removing items from the scene and seeing if the error message goes away. Look first for custom props or other custom content that you imported in as one of these will likely be the culprit.
One other thing it may be is that the project itself is corrupt. When this is suspected it will be wise to drop back to an earlier build of the project before the problem started to appear.
Thanks for the heads up. I have tried to pretty much delete everything a piece at a time, and it looks like you may be right. I recently updated one of my characters and at first it seemed to have a problem with it. But no joy, same problem. So i deleted all the character one by one and replaced them from my library and it seems to have solved the problem. Dont know why it happened. Thought it might have been the recent iclone 7 update but at least i got it to work
Thanks for the help. Woody
