Can't find Exporting transparent video box
Home
Archive
General
https://forum.reallusion.com/Topic488245.aspx
Print Topic
Close Window
By ry456
5 Years Ago
Hi,
I am trying to do the tutorial Export Transparent Video clips for Video Compositing Using DaVinci, I have my scene ready with static png and images with motion clip. However, when I try to render the scene there is no transparent video box for selection. If I click export it does export into the same folders but has a grey background. There is also no Audio selection function under Quality compressor as per the video.
I am using a Mac and have updated to the latest version. Where do I find this box? is the quick capture selection the same? as I can export transparent pngs.
Thanks
By itoo
5 Years Ago
Hello
For mac, select "MOV" as the format in Render settings.
Select "Apple ProRes 4444" as the video codec.
After that, adjust the Output Size and Output Range and click Export.
Now you can create a transparent video.
Please also refer to the manual here
https://manual.reallusion.com/Cartoon_Animator_4/ENU/Pipeline/Content/Resources/ENU/11_Export/General_Export_Settings.htm
37% of original size (was 1385x1011) - Click to enlarge
By ry456
5 Years Ago
Ok, Thanks for your help.
