convert a "Project" to "3Dscene"
https://forum.reallusion.com/Topic488066.aspx
Print Topic | Close Window
By Cartooniste - 5 Years Ago
Good morning all.
I want to convert a "Project" to "3Dscene" so that I can later place this scenery in a "project". I tried to go through "Add to Custom 3Dscene, but no props appear.
Someone has the solution ?
TANKS
By wires - 5 Years Ago
You need to select all of the props in the scene, right click and then click on "Convert To Terrain". Once done you can then save your setup as a 3D Scene. Items such as trees, water or sky are automatically included in a saved 3D Scene.
When creating a new project to use the scene in you need to load it as the first item, otherwise everything present in the project will be deleted and replaced by it. Once added you can then start to build up your project using the 3D Scene as your base.
By animagic - 5 Years Ago
To add to what Gerry mentioned, once the 3D scene is loaded you can then convert any terrain elements back to props by right-clicking and selecting "Convert to Prop".
Thank you for your answers...
