GO Z: Z Brush
https://forum.reallusion.com/Topic487921.aspx
Print Topic | Close Window
By krant - 5 Years Ago
Hey, So I am going through the videos from Reallusion (see screenshot below) and I can't get the mesh to update in CC3. It's only bringing in the body from what I can see and it look's like Z Brush is renaming the original mesh on me. Has anyone had this problem and has figured out away to get this working correctly?
https://forum.reallusion.com/uploads/images/0e041f14-ad3c-4013-b8f9-5bfe.jpg
https://forum.reallusion.com/uploads/images/754b62ce-35d9-422b-98fd-fc55.jpg
I'm really confused. It's a CC3 base but in Z Brush the names are wrong. It also keeps adding numbers on the end even after closing and reopening everything.
https://forum.reallusion.com/uploads/images/ff9b25a2-d09e-42bb-948b-dc63.jpg
https://forum.reallusion.com/uploads/images/a0959579-c8aa-48f7-aacb-f28a.jpg
Last image, this is what pops up when I hit GoZ in Z brush.
https://forum.reallusion.com/uploads/images/dcbacf38-56b8-45e6-a9be-4877.jpg
By Rampa - 5 Years Ago
Try this to fix the naming issue:
Open Zbrush first and go to Preferences > GoZ and click Clear Cache Files. The next time you GoZ from CC3 the subtools will not have (1), (2), etc after the names.
Clicking GoZ All will now map the correct meshes back in CC3. without renaming them.
So always clear the cache before starting a new project.
By vidi - 5 Years Ago
Use not the GOZ Button in Zbrush , rather the ALL Button to send back
because You have sent from CC to Zbrush in Parts.
GOZ Button do only work if in CC was Parts not selected.
This work! I had no idea. Thank you!
