CC3 Body Missing Parts After Disabling Clothing
https://forum.reallusion.com/Topic486049.aspx
Print Topic | Close Window
By whoknows44 - 5 Years Ago
Hi,
A CC3 character I'm working on had parts of it's body go invisible when temporary base clothing was removed. Thus far I can't find any way to restore the character -I'm new to character creator and therefore sort of lost in how to most effectively proceed, appreciate any help i can get.
Thanks in advance
https://forum.reallusion.com/uploads/images/ef19368b-02df-4294-9743-d91c.png
By Colonel_Klink - 5 Years Ago
Hi.
1. Unselect the cloth you wish to show the skin underneath
2. Select Cloth Hide Mesh Settings>Hide Body Mesh Tools
3. Go to Set Visible.
4. Select Show All
That should reset the skin as visible where the cloth was covering. You may have to do this with each piece of cloth.
By animagic - 5 Years Ago
To actually remove the clothing you will need to delete it in the Scene Manager. What you did is just hide it, but the actual mesh is still there and hides the mesh of the body parts.
If you want to keep the clothing in place, then you can make the body parts visible, using Edit Mesh.
A. With the character selected, click "Edit Mesh".
https://forum.reallusion.com/uploads/images/ad26a8af-e2b6-4132-a3ba-63c7.jpg
B. At the Edit Mesh panel, click "Face" and then click "Show All".
https://forum.reallusion.com/uploads/images/4264634e-d9bc-40fa-a3f6-7042.jpg
C. All of the mesh will be shown. Click Edit Mesh (at the top), to close.
https://forum.reallusion.com/uploads/images/896f0e73-ea6e-4a84-ae1d-b688.jpg
Be aware that if you now unhide the clothing that there may be poke-through.
Colonel Klink was slightly faster, but I have pictures!
animagic (6/19/2021)
Thousands of words saved, huh? :D
Two different methods is good
Cheers
Bob
That fixed it, hats of to you guys!  :D
