attach vs link
https://forum.reallusion.com/Topic486046.aspx
Print Topic | Close Window
By debbie harmon - 5 Years Ago
I would like to save a created scene/set to the props.  I am unable to attach swaying trees and flowers.  I can only link but these do not save in the scene when I add the scene to props.  Is there a way to work around that.  I want the whole scene to become an iprop.  Thanks
By animagic - 5 Years Ago
Trees and flowers are different from props. You can save those together as a 3D Scene.
Unfortunately, I can't find anything in the manual, but I tried it out, and a 3D scene saves trees, flowers, and grasses, as well as terrains, the sky and any lights.
If you have props you want to save as well, you can temporarily convert them to terrain items. Right-click on a prop and select Convert to Terrain. Once the 3D Scene has been loaded, you can convert these sub-terrains back to props.
Thank you for the information
