PopcornFX Nature Pack - Spiders Instead of Cockroaches?
https://forum.reallusion.com/Topic485915.aspx
Print Topic | Close Window
By creativevt - 5 Years Ago
Hello! First forum post so please pardon any posting errors. 😀 Might anyone know, if the PopcornFX Nature Pack would allow me to use spider particles in place of the cockroaches that come with the bundle? Trying to figure out how I can create spiders crawling out of a persons mouth and down walls, and PopcornFX is the closest I’ve found to a solution. Also, would I be able to create the wall planes and face mesh in IClone, and use the PopcornFX plugin, and then overlay the IClone footage over real life video footage? A composite of layers? Hoping to arrive at a solution for this effect for a short film I’d like to shoot. Thank you all for any thoughts or suggestions you’re able to provide!.
By wires - 5 Years Ago
You can replace any of the supplied images with one of your choice and it is also possible to render out image files/video sequences with a green screen to overlay in just about any NLE.
Cool about being able to swap particles. Thank you Gerry!
By gordryd - 5 Years Ago
I haven't experimented with this for awhile, but I believe you can insert a series/sequence of 'sprites' that PopFX will cycle thru to give the appearance of animation (you would have to prepare several images of spiders with legs in various 'walking' positions and then insert/replace in the correct order)
