By Ascensi - 5 Years Ago
Wishing that light sources can cause automatic gentle squint morph/eye strain and pupil dilation. I think that might be the last issue to get realism for eyes.i hope either Reallusion makes this or someone else that can make a plugin. there should likely be a bit of a delay of the trigger. Maybe this is connected to Reallusion's SSS because it's almost as if the shader knows to light the object if the light is coming from behind. In this case if the light is behind the pupil morphs rewind but if the light is in front the morphs animate forward.
