natedoggerino (6/12/2021)
also-- when reading the readme.txt file, I noticed it says...
"1. Find "ScriptUI Panel" folder in the following location:
Windows:
Adobe\<Adobe After Effects 2020>\Support Files\Scripts\ScriptUI Panels."
but I dont have a "Adobe After Effects 2020" folder since I only have Adobe CC 2018.
could this be the problem? and if so, how do I deal with this?
Hi...
You should always uninstall/delete all beta files before installing new updates. If you have issues it might be wise to uninstall CTA4 and then do a fresh install of the latest full version using the Reallusion Hub.
For the Script issue, please follow the instructions below. If you are using After Effects 2018 just change the folder structure accordingly such as: Adobe\Adobe After Effects 2018\Support Files\Scripts\ScriptUI Panels
How to install Cartoon Animator - AE Script
Windows:
Adobe\<Adobe After Effects 2018>\Support Files\Scripts\ScriptUI Panels.
*Note: If you can't find the ScriptUI Panels folder, just create a folder with the name "ScriptUI Panels".
2. Copy "Cartoon Animator - AE Script.jsx" into the folder.
3. Restart After Effects, and navigate to Windows > "Cartoon Animator - AE Script.jsx" . Click on it, then you will get a floating panel pop-up. You can dock this panel in your workspace in AE.
*Note: If you have installed the Beta version of the AE Script before, please make sure you delete it before installing the new one.
